I’m creating alert rule groups and the alert rules that are associated to them using some JSON templates that I’m then adding to a filesystem mounted in a Grafana container where the alerting file provisioner can pick them up. This seems to be working fine and my alerts are being created once I add the files and reload the alerting config.
The alerts are using an Azure Monitor datasource. I am adding around 20 instances to the same alert by selecting multiple resources in my query. I can see that the JSON does reflect this when I view it in the Grafana UI (using the view button) but then when I look at the “Instances” tab for that same alert, it only shows 12 instances. This number also tends to fluctuate between 10 - 13 but never gets higher than that.
I’m not quite sure what’s going on, any ideas?
Thanks
