Hi team,
Iam using grafana 5.4 version and my query is
How to get grafana alert logs with metric value in backend server, as of now I can see only info log with some default message and email address
Regards,
gr
Hi team,
Regards,
gr
Hi @gr2, not sure if I understand your question. You can set logging level in config ini file https://grafana.com/docs/v5.4/installation/configuration/#log if that’s what you mean.
