Grafana Alert Fires continuously even when the condition at threshold is not satisfied
  • What Grafana version and what operating system are you using? “grafana:12.0.0; Linux”
  • What are you trying to achieve? “Alert only when threshold condition is satisfied“
  • How are you trying to achieve it? “Configure Alert rule“
  • What happened? “Alert firing, even when the threshold condition is not met“
  • What did you expect to happen? “Alert only when threshold condition is met“
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. “No Errors found in the log”
    Alert rule setting
    Query A
    count by (job, instance) (target_info{group=“KCA”, process_pid!=“”} offset 24h)
    Query B
    count by (job, instance) (target_info{group=“KCA”, process_pid!=“”})
    OR
    (count by (job, instance) (target_info{group=“KCA”, process_pid!=“”} offset 24h) * 0)
    Math C
    $A-$B
    Threshold D IS Above 0
    with following expression
    MY Analytics App SOME instances Down - A=1.000000, B=1.000000, C=0.000000, D=0.000000
Actual Alert Rule Config is
apiVersion: 1
groups:
- orgId: 1
folder: TTK Analytics Apps
interval: 5m
rules:
- uid: ef63d6b4yppmod
title: TTK Analytics App KCA instances Down
condition: B
data:
- refId: A
relativeTimeRange:
to: 0
datasourceUid: mimir
model:
datasource:
type: prometheus
uid: mimir
editorMode: code
expr: count by (job, instance) (target_info{group=“KCA”} offset 24h)
instant: true
intervalMs: 1000
legendFormat: __auto
maxDataPoints: 43200
range: false
refId: A
- refId: B
relativeTimeRange:
to: 0
model:
datasource:
type: prometheus
uid: mimir
editorMode: code
expr: “count by (job, instance) (target_info{group="KCA"})\r\nOR\r\n(count by (job, instance) (target_info{group="KCA"} offset 24h) * 0)”
instant: true
intervalMs: 1000
range: false
refId: B
- refId: C
datasourceUid: expr
model:
conditions:
- evaluator:
params:
- 0
- 0
type: gt
operator:
type: and
query:
params:
reducer:
params:
type: avg
type: query
datasource:
type: expr
uid: expr
expression: round($A - $B)
intervalMs: 1000
refId: C
type: math
- refId: D
datasourceUid: expr
model:
conditions:
- evaluator:
params:
- 0
- 0
type: gt
operator:
type: and
query:
params:
reducer:
params:
type: avg
type: query
datasource:
type: expr
uid: expr
expression: C
intervalMs: 1000
refId: D
type: threshold
noDataState: NoData
execErrState: Error
for: 5m
keepFiringFor: 5m
labels:
alert_type: instance_count_decreased
group: KCA
severity: critical
team: KCA
isPaused: false
  • Did you follow any online instructions? If so, what is the URL? “NO“
How does it fire?
In cases when you join results of two queries, situation when rule evaluation return no data is pretty common. So, in that case “alert” would be DatasourceNoData.
Thanks for your reply, issue is resolved now. it was a simple mistake. I didn’t set the alert condition. now marked “threshold as Alert condition”. It works now..
