bgates
August 23, 2023, 2:34pm
1
Hey all, have a odd question and wasnt sure where to ask so ill likely cross post this in a few locations.
I have a grafana agent that is looking for log files in a few locations, however the directories contain YEARS AND YEARS of historical logs in which we do not care about.
Essentially we want to only grab logs that are from today-forward rather then try to ingest thousands and thousands of log files here is an example config
- job_name: DPALM-LOG
static_configs:
- targets: [localhost]
labels:
POS: 103-cash2
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/103-cash2/*.LOG
Essentially i want it to look for *.LOG but * containing todays date like so 20230823.LOG each day a new file is created with the YEARMODAY format
You can do something whacky like this (haven’t tested):
static_configs:
labels:
POS: 103-cash2
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/103-cash2/2023*.LOG
labels:
POS: 103-cash2
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/103-cash2/2024*.LOG
labels:
POS: 103-cash2
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/103-cash2/2025*.LOG
Let the early months of 2023 naturally process through, and add enough targets to cover yourself for the next 50 or so years.
bgates
August 23, 2023, 4:53pm
3
Hmmmm that would definitely work for the interim…
to bad there isnt a way to match the path using regex
I guess another option is i could have it analyze the log files and if it has a time stamp older then 2023 reject it possibly however currently its also not really reading the time stamp from the log file either
bgates
August 23, 2023, 4:54pm
4
in my loki config.yml
If i set the -from to 2023-01-01 it should actually ignore the older files right?
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
No, that’s schema configuration. If you want to reject old logs on Loki try reject_old_samples and reject_old_samples_max_age (Grafana Loki configuration parameters | Grafana Loki documentation )
bgates
August 24, 2023, 8:38pm
6
limits_config:
enforce_metric_name: false
max_cache_freshness_per_query: ‘10m’
reject_old_samples: true
split_queries_by_interval: 15m
yet it still ingests the logs that are as old as 2015
Are you parsing the timestamp in the log file?
bgates
August 25, 2023, 12:26pm
8
i dont believe this is all i am doing with the files
scrape_configs:
- job_name: integrations/agent
journal:
max_age: 24h
labels:
instance: Collector01
job: integrations/agent
pipeline_stages:
- match:
selector: '{unit!="grafana-agent.service"}'
action: drop
drop_counter_reason: only_keep_grafana_agent_logs
- regex:
expression: "(level=(?P<log_level>[\\s]*debug|warn|info|error))"
- labels:
level: log_level
relabel_configs:
- source_labels: ['__journal__systemd_unit']
target_label: 'unit'
- job_name: integrations/node_exporter_journal_scrape
journal:
max_age: 24h
labels:
job: integrations/node_exporter
relabel_configs:
- source_labels: ['__journal__boot_id']
target_label: 'boot_id'
- source_labels: ['__journal__transport']
target_label: 'transport'
- source_labels: ['__journal_priority_keyword']
target_label: 'level'
- job_name: integrations/node_exporter_direct_scrape
static_configs:
- targets:
- localhost
labels:
__path__: /var/log/{syslog,messages,*.log}
static_configs:
labels:
POS: 102-cash1
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/102-cash1/*.LOG
- job_name: DPALM-NAXML
static_configs:
labels:
POS: 102-cash1
job: DPALM-NAXML
__path__: /mnt/DPALM-LOGS/102-cash1/*.NAXML
- job_name: DPALM-Controller
static_configs:
labels:
POS: 102-cash1
job: DPALM-Controller
__path__: /mnt/DPALM-LOGS/102-cash1/*.controller
- job_name: DPALM-PX1
static_configs:
labels:
POS: 102-cash1
job: DPALM-PX1
__path__: /mnt/DPALM-LOGS/102-cash1/*.PX1
static_configs:
labels:
POS: 101-cash1
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/101-cash1/*.LOG
static_configs:
labels:
POS: 101-cash1
job: DPALM-NAXML
__path__: /mnt/DPALM-LOGS/101-cash1/*.NAXML
static_configs:
labels:
POS: 101-cash1
__path__: /mnt/DPALM-LOGS/101-cash1/*.controller
static_configs:
labels:
POS: 101-cash1
job: DPALM-PX1
__path__: /mnt/DPALM-LOGS/101-cash1/*.PX1
static_configs:
labels:
POS: 101-cash2
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/101-cash2/*.LOG
static_configs:
labels:
POS: 101-cash2
job: DPALM-NAXML
__path__: /mnt/DPALM-LOGS/101-cash2/*.NAXML
static_configs:
labels:
POS: 101-cash2
__path__: /mnt/DPALM-LOGS/101-cash2/*.controller
static_configs:
labels:
POS: 101-cash2
job: DPALM-PX1
__path__: /mnt/DPALM-LOGS/101-cash2/*.PX1
static_configs:
labels:
POS: 101-cash4
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/101-cash4/*.LOG
static_configs:
labels:
POS: 101-cash4
job: DPALM-NAXML
__path__: /mnt/DPALM-LOGS/101-cash4/*.NAXML
static_configs:
labels:
POS: 101-cash4
__path__: /mnt/DPALM-LOGS/101-cash4/*.controller
static_configs:
labels:
POS: 101-cash4
job: DPALM-PX1
__path__: /mnt/DPALM-LOGS/101-cash4/*.PX1
static_configs:
labels:
POS: 101-cash5
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/101-cash5/*.LOG
static_configs:
labels:
POS: 101-cash5
job: DPALM-NAXML
__path__: /mnt/DPALM-LOGS/101-cash5/*.NAXML
static_configs:
labels:
POS: 101-cash5
__path__: /mnt/DPALM-LOGS/101-cash5/*.controller
static_configs:
labels:
POS: 101-cash5
job: DPALM-PX1
__path__: /mnt/DPALM-LOGS/101-cash5/*.PX1
static_configs:
labels:
POS: 103-cash1
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/103-cash1/*.LOG
static_configs:
labels:
POS: 103-cash1
job: DPALM-NAXML
__path__: /mnt/DPALM-LOGS/103-cash1/*.NAXML
static_configs:
labels:
POS: 103-cash1
__path__: /mnt/DPALM-LOGS/103-cash1/*.controller
static_configs:
labels:
POS: 103-cash1
job: DPALM-PX1
__path__: /mnt/DPALM-LOGS/103-cash1/*.PX1
static_configs:
labels:
POS: 103-cash2
job: DPALM-LOG
static_configs:
labels:
POS: 103-cash2
job: DPALM-NAXML
__path__: /mnt/DPALM-LOGS/103-cash2/*.NAXML
static_configs:
labels:
POS: 103-cash2
__path__: /mnt/DPALM-LOGS/103-cash2/*.controller
static_configs:
labels:
POS: 103-cash2
job: DPALM-PX1
__path__: /mnt/DPALM-LOGS/103-cash2/*.PX1
static_configs:
labels:
POS: 103-cash3
job: DPALM-LOG
__path__: /mnt/DPALM-LOGS/103-cash3/*.LOG
static_configs:
labels:
POS: 103-cash3
job: DPALM-NAXML
__path__: /mnt/DPALM-LOGS/103-cash3/*.NAXML
static_configs:
labels:
POS: 103-cash3
__path__: /mnt/DPALM-LOGS/103-cash3/*.controller
static_configs:
labels:
POS: 103-cash3
job: DPALM-PX1
__path__: /mnt/DPALM-LOGS/103-cash3/*.PX1```
If you aren’t parsing timestamp in your log pipeline, then doesn’t matter what the log says the timestamp will be the time it gets sent to Loki. You either have to parse it properly, or you’ll have to make sure you somehow only collect logs from the most resent file, which judging by your naming convention is probably not very easy to do.
bgates
August 25, 2023, 4:55pm
10
how could i parse the time stamps from the logs?
time stamps are formatted like this 06/13/2022 01:00:00.265
Please see Promtail configuration | Grafana Loki documentation , there is a timestamp section in there.
bgates
August 25, 2023, 5:22pm
12
found a comment on another thread from you pertaining to timestamps also
bgates
August 25, 2023, 5:31pm
13
bgates:
scrape_configs:
journal:
max_age: 24h
labels:
pipeline_stages:
- match:
action: drop
- regex:
- labels:
level: log_level
relabel_configs:
journal:
max_age: 24h
labels:
relabel_configs:
static_configs:
- targets:
- localhost
labels:
static_configs:
labels:
POS: 102-cash1
job: DPALM-LOG
static_configs:
labels:
POS: 102-cash1
job: DPALM-NAXML
static_configs:
labels:
POS: 102-cash1
static_configs:
labels:
POS: 102-cash1
job: DPALM-PX1
static_configs:
labels:
POS: 101-cash1
job: DPALM-LOG
static_configs:
labels:
POS: 101-cash1
job: DPALM-NAXML
static_configs:
labels:
POS: 101-cash1
static_configs:
labels:
POS: 101-cash1
job: DPALM-PX1
static_configs:
labels:
POS: 101-cash2
job: DPALM-LOG
static_configs:
labels:
POS: 101-cash2
job: DPALM-NAXML
static_configs:
labels:
POS: 101-cash2
static_configs:
labels:
POS: 101-cash2
job: DPALM-PX1
static_configs:
labels:
POS: 101-cash4
job: DPALM-LOG
static_configs:
labels:
POS: 101-cash4
job: DPALM-NAXML
static_configs:
labels:
POS: 101-cash4
static_configs:
labels:
POS: 101-cash4
job: DPALM-PX1
static_configs:
labels:
POS: 101-cash5
job: DPALM-LOG
static_configs:
labels:
POS: 101-cash5
job: DPALM-NAXML
static_configs:
labels:
POS: 101-cash5
static_configs:
labels:
POS: 101-cash5
job: DPALM-PX1
static_configs:
labels:
POS: 103-cash1
job: DPALM-LOG
static_configs:
labels:
POS: 103-cash1
job: DPALM-NAXML
static_configs:
labels:
POS: 103-cash1
static_configs:
labels:
POS: 103-cash1
job: DPALM-PX1
static_configs:
labels:
POS: 103-cash2
job: DPALM-LOG
static_configs:
labels:
POS: 103-cash2
job: DPALM-NAXML
static_configs:
labels:
POS: 103-cash2
static_configs:
labels:
POS: 103-cash2
job: DPALM-PX1
static_configs:
labels:
POS: 103-cash3
job: DPALM-LOG
static_configs:
labels:
POS: 103-cash3
job: DPALM-NAXML
static_configs:
labels:
POS: 103-cash3
static_configs:
labels:
POS: 103-cash3
job: DPALM-PX1
So in thinking i am going to try this i think
static_configs:
labels:
POS: 103-cash3
job: DPALM-LOG
relabel_configs:
- action: replace
target_label: __timestamp__
regex: '(\d{2}/\d{2}/\d{4} \d{2}:\d{2}:\d{2}\.\d{3})'
I’d recommend you to grab a couple of lines of code and try it out.
Timestamp is not a label. What you need to do is parse parse the timestamp part from the log line (with filter such as regex), then match that timestamp string to a format.
bgates
August 25, 2023, 5:55pm
15
ahhh that makes sense i think i got it now
static_configs:
labels:
POS: 102-cash1
job: TEST
pipeline_stages:
- regex:
expression: '^(?P<timestamp>\d{2}/\d{2}/\d{4} \d{2}:\d{2}:\d{2}\.\d{3})'
- timestamp:
source: timestamp
format: "01/02/2006 15:04:05.000"
bgates
August 25, 2023, 7:14pm
16
did some more refining and this works the best as the config above was giving some 429 errors
pipeline_stages:
- match:
selector: '{job="DPALM-LOG"}'
stages:
- regex:
expression: '^(?P<timestamp>\d{2}/\d{2}/\d{4} \d{2}:\d{2}:\d{2}\.\d{3}) \[\w+\] (?P<message>.*)'
- timestamp:
source: timestamp
static_configs:
- targets:
- localhost
labels:
job: DPALM-LOG
POS: 103-cash1
