Grafana-Agent Error - x509: certificate signed by unknown authority
Hi, i’ve trying to implement grafana-agent using OTLP to exporter traces with .net 6, but I received this error:
"Exporting failed. No more retries left. Dropping data." error=“max elapsed time expired rpc error: code = Unavailable desc = connection error: desc = "transport: authentication handshake failed: x509: certificate signed by unknown authority"” dropped_items=6"
Here is my codes:
grafana-agent.yaml
traces:
  configs:
  - name: default
    remote_write:
      - endpoint: tempo-us-central1.grafana.net:443
        basic_auth:
          username: MY_TEMPO_USER
          password: MY_TEMPO_PASSWORD
    receivers:
      otlp:
        protocols:
          grpc:
docker-compose.yaml
version: '3.4'
services:
  api:
    container_name: device-check
    image: ${DOCKER_REGISTRY-}api
    build:
      context: .
      dockerfile: API/Dockerfile
    ports:
      - "8080:80"
  grafana-agent:
    image: grafana/agent:latest
    container_name: grafana-agent
    command: "-config.file=/etc/agent-config.yaml"
    volumes:
      - ./agent-config.yaml:/etc/agent-config.yaml
    ports:
      - "12345:12345"
my services config in program.cs:
services.AddOpenTelemetry().WithTracing(builder =>
                builder.AddOtlpExporter(options =>
                    options.Endpoint = new Uri("http://grafana-agent:4317");
                .AddConsoleExporter()
                .SetResourceBuilder(ResourceBuilder.CreateDefault().AddService("app"))
                .AddHttpClientInstrumentation()
                .AddAspNetCoreInstrumentation()
                .AddSource("my-source");
            }).StartWithHost();
Can anybody help me? I can’t identify what I’m doing wrong.
I tried to see a lot of examples on internet, but no example helped me.
First try to use latest image = image: grafana/agent:v0.30.1, because it is not clear which version you are using atm. Yes you have :latest tag, but that latest can be downloaded a years ago, when latest tag was different, so you have old image with old CA certs, which is causing your problem.
I changed to the image “grafana/agent:v0.30.1”, but the same error are occuring.
Is a possibility that error is occurring because i’ve trying to implement in my worker laptop, and probably my company has security politics?
Yes, deep packet inspection will use company CA certificate (for tempo-us-central1.grafana.net:443), which is not available in default common CA certs. You can disable cert verification (insecure option) or make used company CA cert available in used Docker image.
Hey, the problem was occurring because my worker laptop had security politics. When I changed to my MAC, the problem didn’t exist more.
Thank’s for the help.
:slight_smile:
I like the concept of “security politics”.
It applies to so many things in the modern world.
Antony.
