- Intro
I’m (finally) migration my grafana instances to 9.4 branch.
Migration works great, really.
But ONE thing is really annoying : it breaks all my displays. (wall mounted displays, users habits on screen …)
Things are displayed bigger. Why and how to reset it to 8.x size ?
Things are just … bigger for no reason. As if the bigger the screen we have, the more space UI designers want us to loose (or they get old and need glasses.)
Right now, when listing things for instance, I have 2 less items in the list, and that’s just one example.
When sometimes I use a “LOG” view, it’s a pain du to the needed scroll.
Apparently it already happened when moving from 6 to 7 (grafana - Default font sizes in 7.x after upgrading. Any way to change it for all dashboards? - Stack Overflow)
9.4.0
- What are you trying to achieve?
Migration from 8.3.3
- What happened?
Overall things works as expected, but are on the ugly side of the force.
my expectations are very low : continue to work
- Can you copy/paste the configuration(s) that you are having problems with?
no, out of the box config
no
Find here another example : Starred items are now so huge … that the “drawer” receives a “scrool arrow” at the bottom (event with still half the screen empty, by the way).
Seriously.
