Hello There,
I want to upgrade my Grafana from version 8 to 9, I just wanted to know which version of victoriametrics is compatible with grafana 9 version.
I was able to run Grafana 9 with Victoriametrics 1.101.0, but wanted to confirm compatability.
Reagards,
VB
probably not the strict answer you were looking for but I was using Grafana 9, 10, 11 with VM versions 1.97.x - I guess it should work too. I guess the HTTP API doesn’t really change, so you should be fine with upgrades.
Hey!
As @dawiddebowski mentioned, the API hasn’t changed, so it should work for any version of VictoriaMetrics up to v1.109.0. If you will see some bugs with compability - than please let us know by creating an issue Sign in to GitHub · GitHub
