I am using Grafana 9.2.10 with Elasticsearch as a data source.
In one of my fields (e.g., A), the data is stored in the following format:
xxx-yyy
I would like to extract only the xxx part (before the hyphen) and then perform a unique count (Uniq Count) aggregation based on this value.
What I have tried so far:
Created a variable and tried using a regex to extract the prefix
Attempted Group by and other Transform options
However, while the variable is recognized, the panel does not show values correctly and aggregation does not work as expected
Additional details:
In Grafana 9.2.10, the Query Editor does not have a Lucene Query / Field input box, so I’m not sure how to reference the variable directly in the panel
The existing Elasticsearch index cannot be modified
Questions:
Is it possible in Grafana 9.2.10 to extract a substring from a field and perform a unique count aggregation without modifying the existing Elasticsearch index?
If yes, could you provide a concrete example of how to configure Variables, Transform, and Query to achieve this?
Thank you very much for your help.
