Background
We are trying to migrate from Grafana 7.5.13 to 8.4.1 in our k8s cluster (deployed via official Grafana helm chart).
We have a bunch of dashboards already defined for cluster monitoring and they are relying on dynamic variables obtained via Prometheus queries.
Problem
Once we swap the image to Grafana 8, dynamic variables are not working due to the lack of response from datasource proxy.
One of the cases - we need to have variable obtained via prom query:
label_values(kube_pod_info,namespace)
In grafana 7 variable queries used GET:
GET https://<grafana7>/api/datasources/proxy/1/api/v1/series?match%5B%5D=kube_pod_info&start=1645620104&end=1645620404
In grafana 8 variable queries seem to be using POST:
POST https://<grafana8>/api/datasources/proxy/1/api/v1/series
form data: match%5B%5D=kube_pod_info&start=1645598928&end=1645620528
For some reason this POST hangs indefintely without respose
Question
- Is it possible to configure grafana 8 to use legacy
GETwhen querying variable values? - If #1 is impossible - what can be causing this issue, and how this can be resolved?
Initial debug from our end:
inside promehteus-server container (both curl-s work OK):
curl localhost:9090/api/v1/series?match%5B%5D=kube_pod_info&start=1645620104&end=164
curl -XPOST localhost:9090/api/v1/series --data-raw 'match%5B%5D=kube_pod_info&start=1645601212&end=1645622812'
inside grafana container (all below wget-s work OK, returning valid prometeus API payloads):
# GET full cluster FQDN
wget -O- http://prometheus-server.monitoring.svc.cluster.local/api/v1/series?match%5B%5D=kube_pod_info&start=1645620104&end=164
# GET short cluster FQDN
wget -O- http://prometheus-server.monitoring/series?match%5B%5D=kube_pod_info&start=1645620104&end=164
# GET grafana proxy endpoint
wget -O- --header='X-User-Name: <my email>' http://grafana.staged-by-discourse.com/api/datasources/proxy/1/api/v1/series?match%5B%5D=kube_pod_info&start=1645620104&end=164
# POST full cluster FQDN
wget -O- --post-data='match%5B%5D=kube_pod_info&start=1645601212&end=1645622812' http://prometheus-server.monitoring.svc.cluster.local/api/v1/series
# POST short cluster FQDN
wget -O- --post-data='match%5B%5D=kube_pod_info&start=1645601212&end=1645622812' http://prometheus-server.monitoring/api/v1/series
# POST grafana proxy endpoint
wget -O- --header='X-User-Name: <my email>' --post-data='match%5B%5D=kube_pod_info&start=1645601212&end=1645622812' http://grafana.staged-by-discourse.com/api/datasources/proxy/1/api/v1/series
