8.3.3 in Ubuntu. -
Define a drop-down variable by querying metrics names. The query has wildcards. The result shall consists of thousands values. -
What happened?
The NGINX log in the graphite server outputs the following:
{Grafana server IP} - - [04/Feb/2024:18:12:46 +0000] "POST /metrics/find?from=1706897504&until=1707070306 HTTP/1.1" 499 0 "-" "Grafana/8.3.3"
A query like this, which works locally fromcurl:
curl -k https://localhost:4040/metrics/find?query=a.*b*.c.d.*
this is how it looks in nginx log:
127.0.0.1 - - [01/Feb/2024:16:56:13 +0000] "GET /metrics/find?query=production.*catod*.catod.vpn_tunnels.* HTTP/1.1" 200 334349 "-" "curl/7.68.0"
I’m not sure it’s a specific configuration, at least I’m not aware of one. I’m not familiar with Grafana configurations (the *.ini file). We use default in principle. -
In Grafana UI:
In grafana logs:
Feb 4 23:14:57 grafana grafana[825]: t=2024-02-04T23:14:57+0000 lvl=eror msg="Data proxy error" logger=data-proxy-log userId=1 orgId=1 uname=admin path=/api/datasources/proxy/148/metrics/find remote_addr={some IP} referer="https://grafana-catoalpha.via.catonetworks.com/d/zWEHinvSk/leonid-playground?orgId=1&editview=templating" error="http: proxy error: context canceled"
Feb 4 23:14:57 grafana grafana[825]: t=2024-02-04T23:14:57+0000 lvl=eror msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=POST path=/api/datasources/proxy/148/metrics/find status=502 remote_addr={same some IP} time_ms=60001 size=0 referer="https://grafana-catoalpha.via.catonetworks.com/d/zWEHinvSk/leonid-playground?orgId=1&editview=templating"
- Did you follow any online instructions? If so, what is the URL?
Not in particular
