[Grafana 8] [Unified Alerting] "Go to panel" button in emails should set a sane time window
Grafana 8.3, hosted on Grafana Cloud.
When I read an alert email, I want to see a panel corresponding to that alerting metric with a relevant time period preselected, even if the alert has already resolved several hours ago.
In my alert email, a “Go to Panel” button is included (if my alert is correctly configured.) I click that button to go to the panel.
What happened?
The panel appeared, but showed data for the current time, not the time when the alert occurred.
I expected the panel to appear with the time window centered around when the alert first appeared and resolved, even if that time period is in the past.
Hello, did you find solution for that? I am looking for the same. I have the URL but I am trying to get the button
