Grafana 8.1.5 panel plugins with angular framework. Is adhoc filtering feature possible to implement by using Angular framework?
I have map panel which is build by using angular framework (initially it was for grafana 6.5.3) with adhoc filtering feature. Basically map is build by using jquery library and when user clicks on some field filter is automatically applied in grafana 6.5.3 that is done by using variableSrv and setAdhocFilter. I have successfully migrated panel to the grafana 8.1.5 but without that feature. I only want to now is it possible to implement adhoc filtering in grafana 8.
