I understand that variable service is no longer available. But I could not find a solution for what I was doing something like this in 6.5:
let variable = _.find(this.variableSrv.variables, {type: ‘adhoc’});
if (!variable) {
/** If template variable doesn’t exist, create new variable with default values */
variable = this.variableSrv.createVariableFromModel({
type: ‘adhoc’,
datasource: ‘MyCustomDatasource’,
hide: 0,
skipUrlSync: false,
});/** Add the newly created variable to the variables list */
this.variableSrv.addVariable(variable);
}const existingFilter = _.find(variable.filters, {key});
/** If filter key already exists just update the value /
if (existingFilter) {
existingFilter.value = value;
/* else add the new filter to the filters list */
else {
variable.filters.push({key, value, operator: ‘=’});
}/** Update the options and refresh the dashboard */
this.variableSrv.updateOptions(variable).then(() => {this.variableSrv.variableUpdated(variable).then(() => {
/** Emit the variable updated event to refresh the dashboard */ this.variableSrv.dashboard.events.emit('template-variable-value-updated'); this.variableSrv.dashboard.events.emit('time-range-updated');});
Is there any replacement service that I could use in AngularJS which would do similar task?
