v9.1.7 -
Get the Google Cloud Monitoring data source up and running -
i need to provisioning datasource -
What happened?
an error appears : Plugin health check failed -
that everything works correctly -
Obviously, i changed my private data to avoid revelated
apiVersion: 1,
datasources: [
access: proxy,
editable: false,
orgId: 1,
type: prometheus,
url: http://xxxxxxxxxxxxxxx,
version: 1
type: stackdriver,
access: proxy,
editable: true,
orgId: 1,
version: 1,
isDefault: false,
jsonData: {
tokenUri: https://oauth2.googleapis.com/token,
clientEmail: service-account-of-google@projectid.iam.gserviceaccount.com,
authenticationType: jwt,
defaultProject: my-project},
secureJsonData: {
privateKey:
“-----BEGIN PRIVATE KEY-----
myprivatekey hash
-----END PRIVATE KEY-----”
Yes, i just receive the next message: Plugin health check failed
this not happen when i add a manual datasource.
The same data entered via manual i have not problem. Only happen when i try to provisioning datasource. -
Yes, the official documentation
welcome to the
forum, @androide
how exactly are you provisioning? Are you using configuration management tools like ansible or terraform? Are you adding .yaml files to a grafana directory? PLease include more details and reproduction steps so we can help you.
Also. try increasing the verbosity of the Grafana server logs to debug and note any errors. For printing to console, set the console logs to debug as well.
Same. If I manually create GCM datasource in Grafana webui, it works fine. In other words by pasting or uploading the json key. When provisioning, the same key produces error “Plugin health check failed”, and GCM dashboards also error:
Error updating options: Unexpected token ‘u’, “unexpected”… is not valid JSON.
@androide did you ever find a solution?
I’m following doc and trying to use:
datasources:
datasources.yaml:
apiVersion: 1
datasources:
- name: Google Cloud Monitoring
type: stackdriver
access: proxy
jsonData:
clientEmail: <service-account>@<my_project>.iam.gserviceaccount.com
defaultProject: <my_project>
secureJsonData:
privateKey: |
<private_key>
Were you ever able to figure this out? I’m also trying to provision the datasource via configuration file and I think I’m running into the same problem you were. I’m able to configure it manually via the Grafana console, but I seem to be missing something with trying to provision via a configuration (using grafana-operator).
