I am using Grafana Enterprise v8.2.4 (d409b0ca16) installed on Ubuntu -
Enable GitHub OAuth login for a team -
I created a GitHub OAuth App, I got the client ID and secret from GutHub. I created a dedicated team on GitHub and for the team ID. I edited/etc/grafana/grafana.ini
as below
#################################### GitHub Auth ##########################
[auth.github]
;enabled = true
;allow_sign_up = true
;client_id = ***
;client_secret = ***
;scopes = user:email,read:org
;auth_url = https://github.com/login/oauth/authorize
;token_url = https://github.com/login/oauth/access_token
;api_url = https://api.github.com/user
;allowed_domains =
;team_ids = ***
;allowed_organizations =
Then I restarted the grafana server
sudo systemctl restart grafana-server
What happened?
Nothing changed -
I expect a github logo to appear on the login page, to allow login using github credentials -
… see above -
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.When visiting the URL
myGrafanaServer/login/github
I got a error message “OAuth not enabled” -
I followed this doc GitHub OAuth2 Authentication | Grafana documentation
relatively incomplete… (In addition to this ticket, I made a feedback with some suggestions for the doc)
