I am getting errors from S3 bucket for throttling . failed to flush user" err="SlowDown: Please reduce your request rate.\n\tstatus code: 503. Is this handled by Loki ?
There are some tuning you can do check yhr ingestion_burst_size and ingestion_rate_mb, also note that when you just implement there is an overhead since loki indexing a lot of data.
Hope it helps.
Good Luck
S3 throttles by prefix within a bucket, so if you have the ability to use Loki in multi-tenant mode, this will put each of the chunks in a tenant prefix.
Other considerations are to make sure you aren’t sending really high cardinality data, more streams means more chunks which means more IOPS to S3.
You could paste your config also and I could check if you have anything misconfigured.
config: |
auth_enabled: false
server:
log_level: debug
# Must be set to 3100
http_listen_port: 3100
grpc_server_max_recv_msg_size: 67108864
grpc_server_max_send_msg_size: 67108864
distributor:
ring:
kvstore:
store: memberlist
ingester:
# Disable chunk transfer which is not possible with statefulsets
# and unnecessary for boltdb-shipper
max_transfer_retries: 0
chunk_idle_period: 1h
chunk_target_size: 1536000
max_chunk_age: 1h
flush_check_period: 60s
lifecycler:
join_after: 0s
ring:
replication_factor: 2
kvstore:
store: memberlist
memberlist:
join_members:
- {{ include "loki.fullname" . }}-memberlist
limits_config:
ingestion_rate_mb: 10
ingestion_burst_size_mb: 20
max_concurrent_tail_requests: 20
max_cache_freshness_per_query: 10m
schema_config:
configs:
store: boltdb-shipper
object_store: aws
schema: v11
index:
prefix: loki_index_
period: 24h
chunk_store_config:
max_look_back_period: 336h
table_manager:
retention_deletes_enabled: true
retention_period: 336h
storage_config:
aws:
s3: s3://ap-southeast-1/swiggy-loki
boltdb_shipper:
active_index_directory: /var/loki/index
shared_store: s3
cache_location: /var/loki/cache
query_range:
# make queries more cache-able by aligning them with their step intervals
align_queries_with_step: true
max_retries: 5
# parallelize queries in 15min intervals
split_queries_by_interval: 15m
cache_results: true
results_cache:
cache:
enable_fifocache: true
fifocache:
max_size_items: 1024
validity: 24h
frontend_worker:
frontend_address: {{ include "loki.queryFrontendFullname" . }}:9095
frontend:
log_queries_longer_than: 5s
compress_responses: true
compactor:
shared_store: s3
