getTimeSrv in plugin
Dear all,
I have a problem accessing the time frame of my dashboard from within my developed plugin.
    V11.4.0
    Developing a panel plugin with access to timeSrv to adjust time frame from within my plugin.
    import getTimeSrv from @grafana/runtime is not working. Anywhere I can find it?
  • What happened?
    Error: getTimeSrv is not a function
    Obviously my time frame should have changed according to my panel plugin
Any ideas or hints what can solve my problem?
Thank you in advance.
