Grafana v8.1.1 on windows -
add a dashboard with the API -
Im trying to add a dashboard with the API but i get the following error: ‘A dashboard with the same name in the folder already exists’
When I use /api/search?query= to find the name of the dashboard it is not found nor does it exist on the Grafana server.
How can i solve this? Is there a reason why this happens?
