Hello, I have a problem with my servers appearing on the Geomap, I have the coordinates in the Zabbix inventory, but it doesn’t locate them automatically. How can I get this information within Zabbix to be displayed on the Grafana Geomap? Can anyone tell me?
Grafana: 11
Zabbix: 6.0
vaduga
June 21, 2024, 1:27am
2
if it doesn’t autolocate may be you should specify location fields in geomap panel manually? The problem is unclear with no further details
what does the data coming from zabbix look like?
Hello, I get the data directly from Zabbix, with the API
yes but what does the data look like?
Hello, the latitude and longitude data is in the Zabbix inventory
I don’t know which option would locate this Zabbix Inventory data in Grafana’s Geomap panel
what does the data look like when you query it in grafana
vaduga
September 14, 2024, 6:25am
9
Your Zabbix inventory data won’t magically appear in Geomap. You have to query it from Zabbix Mysql (PostgresDB). Example from other map panel Zabbix hosts map tutorial - Mapgl Grafana plugin
