Geomap Routes: Multiple Polylines
    Grafana v9.5.2 (cfcea75916
    I’m wanting to plot multiple route lines using the GeoMap plugin to plot the routes of multiple vehicles.
    I have an InfluxDB instance which I’m populating with with coordinate data, as well as other metadata, representing a series of vehicles. Rather than drawing a single line, I’d like to group the data by various fields to produce multiple routes.
  • What happened?
    Currently, only the first group is being rendered. For reference, below is the Flux query being used
import "influxdata/influxdb/schema"
from(bucket: v.defaultBucket)
  |> schema.fieldsAsCols()
  |> filter(fn: (r) => r["_measurement"] == "vehicle_event")
  |> sort(columns: ["_time"])
  |> group(columns: ["Id"])
Multiple ploylines representing the different groups. Wondering if this is a supported use case and if not, if anyone knows if it’s planned.
No errors from the UI. I do however see a Data dropdown in the Map Layer section of the panel configuration and can see what looks like a separate data set for each group from the query. I don’t seem to be able to change the data set to a different group top test different blocks of data.
I have looked at the Geomap panel instructions on the grafana website, bit doesn’t give much detail other than ensuring the data has coordinates
I’ve been having the same issue - did you ever find out a way to do this?
No, I ended it parking it for the time being. I did subscribe to the Geomap epic Epic: Geomap · Issue #58543 · grafana/grafana · GitHub as I believe it’s still a beta feature and others have reported some vaguely similar behaviour. I’m mainly waiting for the stable release before retesting
Can you share a .csv of the output of your data (from Influx Data Explorer) so that others can use it to test / troubleshoot / help?
might want to look at this one
https://play.grafana.org/d/geomap-route-layer/panel-tests-geomap-route-layer?orgId=1
hi, i ran into exactly the same problem 3 weeks ago, i created the feature to have multiple paths in the same geomap layer in my grafana fork. I already created the pr for the changes. Here is the link Geomap: Group by field option in routes layer by MilanRiccardo03 · Pull Request #102259 · grafana/grafana · GitHub
