Grafana v9.5.2
Hi There !
I want to make a script that automaticly write the json of a wethermap dashboard.
I’m making the script in Python. When i import it in Grafana all the query are good, nodes are created and links too. But i have an issue :
“Cannot read properties of undefined (reading ‘index’)”
So i try somethings, and i find that if i create the same map with the same querys but manually, it works. So i compare the two JSON panels of weathermaps and the only difference was the id of nodes and links. When i copy past from the manually map to the automatic one it worked.
So my question is how i can generate from outside Grafana id that are valid.
