Generate graphs for active triggers only
Hi All,
i m using Zabbix 3.0 and we want to implement Grafana for its Dashboard.
We have a requirement to have a dashboard that displays graphs only for active triggers i.e if the triggers are active then show the graph else no.
Is there any way to achieve this.
can a graph panel value be changed based on values of Trigger panel ?
Thanks,
Raza
