Gauge - change the positive/negative side
If there is a positive data, the gauge goes to the right side, the data is negative it goes to the left side. How can I change this?
can I change the side for negative or positive data?
you can multiply your values with -1. :upside_down_face:
I Know. But thats not the same.
you can use Business Chart plugin.
