Forwarding Generic OAuth access token to a Loki datasource
    • Grafana 13.2.3 (grafana/grafana focker image)
    • Forwarding scopes provided by Generic OAuth authentication via a JWT access token to the proxy sitting in front of my Loki backend so it can accept or deny requests based on those scopes.
    • I configured a Loki datasource with the URL of the proxy sitting in front of my Loki backend, and selected “Authentication method: Forward OAuth Identity”
    • I configured the Generic OAuth authentication plugin
  • What happened?
    • Loky proxy only received following headers:
      • accept
      • accept-encoding
      • accept-language
      • host
      • sec-ch-ua
      • sec-ch-ua-mobile
      • sec-ch-ua-platform
      • sec-fetch-dest
      • sec-fetch-mode
      • sec-fetch-site
      • user-agent
      • x-datasource-uid
      • x-forwarded-for
      • x-grafana-id
      • x-grafana-org-id
      • x-grafana-referer
      • x-grafana-user
      • x-plugin-id
    • I expected access token and ID Token obtained from Generic OAuth provider to be forwarded to the proxy sitting in front of Loki via those headers:
      • Authorization
      • X-ID-Token
Having information from original Generic OAuth access token (eg: scopes) in x-grafana-id JWT token would also work for me.
Hi @troglogeek, your datasource setup looks right. Since the x-grafana-* headers reach your proxy, the Loki plugin is forwarding headers fine, and the problem is that Grafana isn’t attaching the OAuth token. In 13.2.3 it skips the token when →
The user didn’t log in via Generic OAuth (for example a local admin or a service account), or Grafana has no stored OAuth session for them. Log out, sign in with the OAuth button, and run the query from Explore.
The token refresh failed. Log in again to get a fresh token, and check the log error to see why your provider rejected the refresh.
The query isn’t from a user session (alert rules, background jobs).
To see which one it is, check the Grafana server logs while you run the query. Look for →
The specified user's auth provider is not oauth
No external session found for user
Failed to refresh OAuth token
Also, x-grafana-id is a JWT signed by Grafana for the user’s identity, not your provider’s token. Decode it to see which claims it contains before relying on it for scope checks.
(tried to make a reply before but it seems to have been blocked, maybe because I tried to include too much log)
Hi @infofcc3 , thank you a lot for your strong and helpful response.
To test oauth access token forwarding I:
  • login as admin, delete the test user (just in case), log out
  • login using generic oauth
  • immediately reach for Explore tab and use the labels dropdown which initiates a request to ask for available labels
So I should not fall in the circumstances you mentioned, I also did not see any of the log patterns you gave me, the only odd log that seems worth mentioning (I previously included the whole login log segment but the answer disappeared):
logger=user.sync t=2026-11-06T14:52:02.75111564Z level=warn msg="The SAML catalog used for this login has an incorrect version format" catalogVersion=
logger=context userId=0 orgId=0 uname= t=2026-11-06T14:52:02.751329706Z level=info msg="Request Completed" method=GET path=/login/generic_oauth status=302 remote_addr=172.128.1.1 time_ms=68 duration=68.439707ms size=24 referer=http://localhost:3000/ handler=/login/:name status_source=server
The SAML warn seems odd as I use OIDC, not SAML…
I anyone has a clue on what I may have missed that prevent access token from being forwarded? That would help me a lot.
I also want to mention that I audit the headers being forwarded to loki using a mitmproxy, worth mentioning because in similar posts I saw several people trying to see the headers using browser debugging console, which is obviously not able to the what is happening between Grafana data source proxy and the datasource.
Finally got it working by enabling use_refresh_token = true in [auth.generic_oauth]
Do someone know if this requirement is expected? I found no such thing in documentation or the web.
Does this point out
  • a flaw in my OIDC set-up?
  • a flaw in Grafana Documentation?
  • a bug in Grafana?
Many thanks again to @infofcc3 that gave me the strength to keep digging instead of finding a dirty work around.
Before concluding that Grafana omitted the token, where was this header list captured: at the proxy ingress, or on the request the proxy forwarded to Loki? The presence of x-grafana-* headers does not distinguish those two cases.
For one Explore query made by the OAuth user, compare only the presence or absence of Authorization and X-ID-Token at both hops, without logging their values. If they arrive at the proxy but disappear downstream, check its header forwarding/authentication configuration first. That would narrow the search before changing Grafana’s OAuth settings.
The Loki data source docs (Configure the Loki data source | Grafana documentation) describe Forward OAuth Identity as forwarding the querying user’s access token and, when available, ID token.
