Folder ID's Not Importing
    Grafana OSS v7.5.7 on CentOS 8 Stream
    Importing folders via the API
    Using the API to import dashboards
  • What happened?
    Dashboards imported successfully however their folder ID’s don’t seem to match what was in the JSON
    Folder IDs match upon import. Them not matching causes issues on panel types that reference the folder ID for a search (eg. alert list and dashboard list).
    I don’t believe there are relevant config files in this case but if some are needed, I can upload
    No errors in the UI; the import processes returned HTTP code 200 as expected
    Followed docs and standard api practices.
