Hello!
I have the following topic.
Let’s say I have the following data
18.11.2023 13:00 Address_1
18.11.2023 14:00 Address_2
18.11.2023 15:00 Address_1
18.11.2023 16:00 Address_3
18.11.2023 17:00 Address_1
I want to draw a bar chart showing me groupd by address the number of visits in the choosen time periode. Like:
Address_1 3
Address_2 1
Address_3 1
Unfortunately I am not able to combine group, count, … to reach the right result
From searching I tried different hints … but none worked e…g
from(bucket: "iobroker")
|> filter(fn: (r) => r["_measurement"] == "Adresse" and r["_field"] == "value")
|> duplicate(column: "_value", as: "new_column")
|> group(columns: ["new_column"])
|> count()
grant2
November 19, 2023, 2:46pm
2
Hi @dieterlind
How about something like this?
from(bucket: "your_bucket")
|> range(start: 2023-11-18T13:00:00Z, stop: 2023-11-18T17:00:00Z)
|> filter(fn: (r) => r["_measurement"] == "your_measurement") // Replace with your actual measurement name
|> group(columns: ["_field"])
|> count(column: "_value")
|> yield(name: "count")
This results in:
Actually I just want the different “values” on the left side and the count(distinct) on the right side …
grant2
November 19, 2023, 11:53pm
4
What are all the possible values for _measurement? If its Address_1, Address_2, etc. then try changing these lines as shown & report back…
|> group(columns: ["_measurement"])
|> count()
Hi!
Yes, it can be several addresses which occur 1 - n times and shall be grouped.
After changing I get
So the result is the total number of addresses found but not grouped by addresses
The different addresses are in the “_value” column
grant2
November 20, 2023, 3:36pm
6
What happens if you put a distinct function before the count function, like this?
|> distinct(column: "_measurement")
like this?
|> filter(fn: (r) => r["_measurement"] == "Adresse")
gives an error
Status: 500. Message: invalid: runtime error @5:6-5:38: distinct: schema collision: cannot group boolean and string types together
this also doesn’t work with the same error:
|> group()
grant2
November 20, 2023, 5:15pm
8
How about this…Could you run this query in Influx Data Explorer and then upload here the csv of the output? That will make it easier for the community to evaluate and help you find a solution.
|> yield(name: "help")
If the csv-export button would still be available I could provide it … but somehow this is gone
wasn’t the button typically next to the timeframe to select or “view raw data”?
yosiasz
November 20, 2023, 6:22pm
10
Something like
measurement,tag1,location,.parking-position.latitude,time
.parking-position.latitude,parking,Accord,41.7972,1700152037000000873
measurement,tag1,location,.parking-position.longitude,time
.parking-position.longitude,parking,Accord,-74.2319,1700152037000000873
Type it in here manually
grant2
November 21, 2023, 12:36am
11
I think it was last seen in v2.6
Maybe you can copy/paste the data (or at least ~10 representative lines) so we can try to help you.
