Grafana v10.2.0. Grafana is running as a Docker in a Ubuntu machine -
Find the metrics that are related to the SRE golden signals -
We are having our domains hosted in Appengine (GAE). We got the response count, instance count, 5xx errors, requests based on country and the Response latency. -
What happened?
For example, we are trying to create a dashboard based on IP address, we cannot see this option. Is that possible in Grafana? -
Likewise what are the other metricises we can use to get more insights based on the SRE golden signals -
Anyone can help me on this
Hi @rosarioboscoofficial and welcome to the Grafana forum.
Have you been able to successfully connect your datasource(s) to Grafana? If yes, what are the datasources?
I have successfully connected Google cloud Monitoring
