Hi everyone,
I am trying to set an IP for the Redis Database It was installed using helm from bitnami/redis kubectl gives the following info :
While configuration on grafana looks like this
What am i missing?
Any help is highly appreciated, Blessings.
I realized it can also be the name of the running service since they’re both on the same network and so this was used instead… but still fails even when there is an http:// added to it Any suggestions? ^^
Solution was to use Prometheus on localhost:9090 as my Data Source and then import the JSON file/URL hope this will help
