Hi all,
New user here. I have data in Grafana logged at every 30 seconds. I am trying to take the average value for every 15 minute increment for a selected time period and then display the maximum value of those increments. So the result should be a single value. Currently I am trying
SELECT max(“field”) FROM “place” WHERE (“device” =~ /^$SystemSelect$/) AND $timeFilter GROUP BY time(15m), “device” fill(linear)
does group by time(15m) not accomplish taking the 15 minute average?
v.7.3.7 -
above -
above -
What happened?
The resulting values were too high, likely not an average -
The value to reflect the maximum 15 minute average. For example the average power consumption from 2:30 to 2:45 was 500 kW and this was the maximum value of the selected time period that is the value that should be returned.
