Filter via Timestamp
  • What Grafana version and what operating system are you using? 9.5.5
  • What are you trying to achieve? I would like to filter my log results by “Timestamp”
  • How are you trying to achieve it? Would like to know if it is possible. I am a newbie…
  • What happened?
Which visualization are you using?
Could you provide examples of what you have now and what you want to achieve?
For example, Table supports column filters:
