Grafana v10.3.3 (252761264e) raspian buster. -
Display in a Stat panel the mean value of 2/3 columns of an influxdb query calculated in another panel. -
I’ve applied a transformation to select the two columns that I am interested on, before calculating the mean using the “value options” → calculate → Mean function. -
What happened?
The panel displays the two mean values for a couple of seconds, but soon after one of the two values disappears. This happens always, i.e., it is reproducible. -
To keep the two target mean values. -
The problem might be related to the actual influxdb query, which although it does not outputs any error, I’m not overly confident with. The overall objective of this project is to calculate and display the daily average hours of sunlight on each side of my roof, these are the 2/3 columns, and the last column is a separate calculation of the amount of energy which would be generated by a PV array in one side of the roof minus average energy consumption (days_of_autonomy column below). The query is as follows
from(bucket: "DOMOTICZ")
|> filter(fn: (r) => r._measurement == "Solar-Radiation")
|> filter(fn: (r) => r["idx"] == "23")
|> map(fn: (r) => ({r with _value: r._value / (9876.0*1000.0)}))
|> window(every: 1d)
|> integral(unit: 1h)
|> map(fn: (r) => ({r with days_of_autonomy: r._value*10.0*0.435 - 4.70 }))
|> duplicate(column: "_stop", as: "_time")
|> window(every: inf)
No, that’s what’s most strange…the stat panel simply updates itself by deleting one of the two mean values (see attached images)
Before:
After:
N/A
