I’m checking the first option with the time series bucket in Heatmap. Below is the result. Indeed, each line in the diagram corresponds to one column name for the magnitudes, but with proper renaming this could be mapped to frequencies. However the deviation is not visible that well as in the previous diagram which has the y axis in logarithmic scale. Is there a way to apply a similar scaling in the time series bucket mode?
By the way, I looked at the advanced variable options in the Grafana documentation and if I modify my query to something like this:
SELECT ${amplVar:doublequote} as yAxis, ${freqVar:doublequote} as xAxis FROM "meas_ext" WHERE ("deviceID" = 'CurSensor_MCU') AND $timeFilter
I’m now able to dynamically select and add plots on the same diagram.
