What Grafana version are you using?
Latest Grafana Enterprise Docker Image -
I’m trying to calculate the self time of spans for a specific trace ID. -
With the Add field from calculation transformation and the binary operation mode. My operation is “duration Trace - duration(sum)” or rather “duration Span - duration Children”
TLDR:
I have two queries with the TraceQL${traceId)
. One of the queries I grouped by parentSpanID and then summed the duration to get the duration of all child spans. Than I joined the queries by parentSpanID = spanID and am now trying to calculate the self time as described above. -
My question
Not all spans have child spans and for these my self time is NaN. Is there any way to replace the NaN values with the value of the duration Span field of that row? Or replace the duration Children with 0 so that the calculation still works?
