Failed to select test alert..SMTP not configured check your grafana.ini
I have installed grafana through docker container …i am trying to send test alert in the dashboard i am getting error..
i have changed smtp configurations grafana.ini …still i am facing this issue
i am using AWS work mail configuration for alerts
Grafana.ini file
please ;enabled = true
;host = smtp.awsapps.com:465
;user = username
If the password contains # or ; you have to wrap it with triple quotes. Ex “”“#password;”“”
;password =
;cert_file =
;key_file =
;skip_verify = true
;from_address = user email adress
;from_name = Grafana
EHLO identity in SMTP dialog (defaults to instance_name)
;ehlo_identity = dashboard.example.com
SMTP startTLS policy (defaults to ‘OpportunisticStartTLS’)
;startTLS_policy = NoStartTLS
