Grafana Cloud 9.2.4 (2022-11-07) and I am trying to monitor Alamalinux 9 Arm64 server.
- What are you trying to achieve?
To monitor Linux Server.
- How are you trying to achieve it?
By following the instruction mentioned in the dashboard.
- What happened?
--- Using package system rpm. Downloading and installing package for arm64
warning: /var/tmp/rpm-tmp.V1BHxn: Header V4 RSA/SHA512 Signature, key ID 24098cb6: NOKEY
--- Retrieving config and placing in /etc/grafana-agent.yaml
Failed to retrieve config
To install config successfully.
- Can you copy/paste the configuration(s) that you are having problems with?
sudo ARCH=arm64 GCLOUD_STACK_ID="REDACTED" GCLOUD_API_KEY="REDACTED" GCLOUD_API_URL="https://integrations-api-eu-west.grafana.net" /bin/sh -c "$(curl -fsSL https://raw.githubusercontent.com/grafana/agent/release/production/grafanacloud-install.sh)"
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Oops! Something went wrong. Make sure the install instructions were copied correctly and check for any optional configurations. If you’re still running into issues, read the troubleshooting instructions.
- Did you follow any online instructions? If so, what is the URL?
I even tried to add config in /etc/grafana-agent.yaml manually but it didn’t work.
Logs from journalctl -b -u grafana-agent.service are like this:
Stopping Monitoring system and forwarder...
grafana-agent[96201]: ts=2022-11-15T14:47:48.192934156Z caller=gokit.go:72 level=info msg="=== received SIGINT/SIGTERM ===\n*** exiting"
grafana-agent[96201]: ts=2022-11-15T14:47:48.206520903Z caller=node.go:319 level=info agent=prometheus component=cluster msg="shutting down node"
grafana-agent[96201]: ts=2022-11-15T14:47:48.206576863Z caller=node.go:345 level=info agent=prometheus component=cluster msg="node shut down"
grafana-agent[96201]: ts=2022-11-15T14:47:48.206609143Z caller=node.go:169 level=info agent=prometheus component=cluster msg="node run loop exiting"
grafana-agent[96201]: ts=2022-11-15T14:47:48.206664464Z caller=config_watcher.go:104 level=info agent=prometheus component=cluster msg="config watcher run loop exiting"
grafana-agent[96201]: ts=2022-11-15T14:47:48.210548443Z caller=main.go:74 level=info msg="agent exiting"
systemd[1]: grafana-agent.service: Deactivated successfully.
systemd[1]: Stopped Monitoring system and forwarder.
systemd[1]: Started Monitoring system and forwarder.
grafana-agent[96278]: ts=2022-11-15T14:47:48.823597121Z caller=server.go:191 level=info msg="server listening on addresses" http=127.0.0.1:9090 grpc=127.0.0.1:9091 http_tls_enabled=false grpc_tls_enabled=f>
grafana-agent[96278]: ts=2022-11-15T14:47:48.828172623Z caller=node.go:85 level=info agent=prometheus component=cluster msg="applying config"
grafana-agent[96278]: ts=2022-11-15T14:47:48.828738906Z caller=remote.go:180 level=info agent=prometheus component=cluster msg="not watching the KV, none set"
grafana-agent[96278]: ts=2022-11-15T14:47:48.833841612Z caller=zapadapter.go:78 level=info component=traces msg="Traces Logger Initialized"
grafana-agent[96278]: ts=2022-11-15T14:47:48.846206393Z caller=reporter.go:103 level=info msg="running usage stats reporter"
systemd[1]: Stopping Monitoring system and forwarder...
grafana-agent[96278]: ts=2022-11-15T14:51:07.310641168Z caller=gokit.go:72 level=info msg="=== received SIGINT/SIGTERM ===\n*** exiting"
Sorry, if I missed something!
Thank You!
