Failed to load the data source configuration for Loki: Unable to fetch alert rules. Is the Loki data source properly configured?
I am currently in the process of setting up Loki on a Docker Simple scalable deployment , logs are getting stored in aws s3 bucket but alerting rule age not getting displayed and loki .
also and loki datasource alerts are greyed out
Here i am attaching the config and docker file.
config file.
    server:
      http_listen_port: 3100
    memberlist:
      join_members:
        - loki:7946
    schema_config:
      configs:
          store: boltdb-shipper
          object_store: s3
          schema: v11
          index:
            prefix: index_
            period: 24h
    storage_config:
      aws:
        s3: s3://<Region>/<Bucket-Name>
        bucketnames: "<Bucket-Name>"
        region: "<Region>"
        sse:
          type: "SSE-S3"
        access_key_id: "<key ID>"
        secret_access_key: "<Access key>"
    common:
      path_prefix: /loki
      replication_factor: 1
      ring:
        kvstore:
          store: memberlist
    ruler:
      storage:
        type: s3
        s3:
          bucketnames: <Bucket-Name>
          region: "<Region>"
          sse:
            type: "SSE-S3"
      rule_path: /etc/loki/rules
      alertmanager_url: http://alertmanager:9093
      ring:
        kvstore:
          store: inmemory
      enable_api: true
      enable_alertmanager_v2: true
Docker File
version: "3"
networks:
  loki:
services:
  read:
    image: grafana/loki:2.8.2
    command: "-config.file=/etc/loki/config.yaml -target=read"
    ports:
      - 3101:3100
      - 7946
      - 9095
    volumes:
      - ./loki-config.yaml:/etc/loki/config.yaml
    depends_on:
      - minio
    healthcheck:
      test: [ "CMD-SHELL", "wget --no-verbose --tries=1 --spider http://localhost:3100/ready || exit 1" ]
      interval: 10s
      timeout: 5s
      retries: 5
    networks: &loki-dns
      loki:
        aliases:
          - loki
  write:
    command: "-config.file=/etc/loki/config.yaml -config.expand-env=true -target=write"
    ports:
      - 3102:3100
      - 7946
      - 9095
    volumes:
    healthcheck:
      interval: 10s
      timeout: 5s
      retries: 5
    depends_on:
      - minio
    networks:
      <<: *loki-dns
  promtail:
    image: grafana/promtail:2.8.2
    volumes:
      - ./promtail-local-config.yaml:/etc/promtail/config.yaml:ro
      - /var/run/docker.sock:/var/run/docker.sock
    command: -config.file=/etc/promtail/config.yaml
    depends_on:
      - gateway
    networks:
      - loki
  minio:
    image: minio/minio
    entrypoint:
      - sh
      - -euc
        mkdir -p /data/loki-data && \
        mkdir -p /data/loki-ruler && \
        minio server /data
    environment:
      - MINIO_ROOT_USER=loki
      - MINIO_ROOT_PASSWORD=supersecret
      - MINIO_PROMETHEUS_AUTH_TYPE=public
      - MINIO_UPDATE=off
    ports:
      - 9000
    volumes:
      - ./.data/minio:/data
    healthcheck:
      test: [ "CMD", "curl", "-f", "http://localhost:9000/minio/health/live" ]
      interval: 15s
      timeout: 20s
      retries: 5
    networks:
      - loki
  grafana:
    image: grafana/grafana:latest
    environment:
      - GF_PATHS_PROVISIONING=/etc/grafana/provisioning
      - GF_AUTH_ANONYMOUS_ENABLED=true
      - GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
    depends_on:
      - gateway
    entrypoint:
      - sh
      - -euc
        mkdir -p /etc/grafana/provisioning/datasources
        cat <<EOF > /etc/grafana/provisioning/datasources/ds.yaml
        apiVersion: 1
        datasources:
          - name: Loki
            type: loki
            access: proxy
            url: http://gateway:3100
            jsonData:
              httpHeaderName1: "X-Scope-OrgID"
            secureJsonData:
              httpHeaderValue1: "tenant1"
        EOF
        /run.sh
    ports:
      - "3000:3000"
    healthcheck:
      test: [ "CMD-SHELL", "wget --no-verbose --tries=1 --spider http://grafana.staged-by-discourse.com/api/health || exit 1" ]
      interval: 10s
      timeout: 5s
      retries: 5
    networks:
      - loki
  gateway:
    image: nginx:latest
    depends_on:
      - read
      - write
    entrypoint:
      - sh
      - -euc
        cat <<EOF > /etc/nginx/nginx.conf
        user  nginx;
        worker_processes  5;  ## Default: 1
        events {
          worker_connections   1000;
        http {
          resolver 127.0.0.11;
          server {
            listen             3100;
            location = / {
              return 200 'OK';
              auth_basic off;
            location = /api/prom/push {
              proxy_pass       http://write:3100\$$request_uri;
            location = /api/prom/tail {
              proxy_pass       http://read:3100\$$request_uri;
              proxy_set_header Upgrade \$$http_upgrade;
              proxy_set_header Connection "upgrade";
            location ~ /api/prom/.* {
            location = /loki/api/v1/push {
            location = /loki/api/v1/tail {
            location ~ /loki/api/.* {
        EOF
        /docker-entrypoint.sh nginx -g "daemon off;"
    ports:
      - "3100:3100"
    healthcheck:
      test: ["CMD", "service", "nginx", "status"]
      interval: 10s
      timeout: 5s
      retries: 5
    networks:
      - loki
  flog:
    image: mingrammer/flog
    command: -f json -d 1s -l
    networks:
      - loki
could someone help here?
Hi @amanraj Have you added this Loki instance as a data source in Grafana?
@amanraj
here is another docker-compose file you can try
version: "3"
networks:
  loki:
services:
  loki:
    image: grafana/loki:2.8.0
    ports:
      - "3100:3100"
    command: -config.file=/etc/loki/local-config.yaml
    networks:
      - loki
  promtail:
    image: grafana/promtail:2.8.0
    volumes:
      - /var/log:/var/log
    command: -config.file=/etc/promtail/config.yml
    networks:
      - loki
  grafana:
    environment:
    entrypoint:
      - sh
      - -euc
        apiVersion: 1
        datasources:
        - name: Loki
          type: loki
          access: proxy
          orgId: 1
          url: http://loki:3100
          basicAuth: false
          isDefault: true
          version: 1
          editable: false
        EOF
        /run.sh
    ports:
      - "3000:3000"
    networks:
      - loki
yes, @soniaaguilar that is done in grafana section of Docker file.
