I am currently using simple scalable deployment mode ( 3 reads, 6 write, Helm Chart version: 3.7.0 ) for my logging system. As I have to ingest around 2TB data per day in Loki, the search performance is not sufficient (Summary.BytesProcessedPerSecond 409 MB) for production.
I’ve read blog posts “How to improve Loki Performance” and was tried to follow the step in the doc (Query Frontend | Grafana Loki documentation), I can successfully run a query-frontend pod, but failed in connecting to the Loki read pods.
Besides, according to the Architecture from the doc (Deployment modes | Grafana Loki documentation), query frontend seems to be part of the read pods.
So, my questions are, how to enable the query frontend in my case? Or only distributed deployment mode achieves the goal?
Here’s my config.yaml
auth_enabled: false
common:
path_prefix: /var/loki
replication_factor: 1
storage:
s3:
access_key_id: access_key_id
bucketnames: bucketnames
endpoint: s3.region.amazonaws.com
http_config:
idle_conn_timeout: 600s
insecure: false
region: region
s3forcepathstyle: false
secret_access_key: secret_access_key
ingester:
autoforget_unhealthy: true
chunk_encoding: snappy
chunk_idle_period: 30m
chunk_retain_period: 0s
chunk_target_size: 1572864
flush_check_period: 15s
max_transfer_retries: 0
limits_config:
enforce_metric_name: false
ingestion_burst_size_mb: 100
ingestion_rate_mb: 25
max_cache_freshness_per_query: 10m
max_query_parallelism: 16
per_stream_rate_limit: 15mb
per_stream_rate_limit_burst: 30mb
reject_old_samples: true
reject_old_samples_max_age: 720h
retention_period: 720h
split_queries_by_interval: 15m
memberlist:
join_members:
- loki-memberlist
querier:
engine:
max_look_back_period: 30m
timeout: 30m
query_range:
align_queries_with_step: true
query_scheduler:
scheduler_ring:
instance_interface_names:
- lo
ruler:
storage:
s3:
insecure: false
region: region
Secret_access_key: secret_access_key
type: s3
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
object_store: s3
schema: v12
store: boltdb-shipper
server:
grpc_listen_port: 9098
grpc_server_max_recv_msg_size: 83386080
grpc_server_max_send_msg_size: 83386080
http_listen_port: 3100
http_server_idle_timeout: 1800s
http_server_read_timeout: 1800s
http_server_write_timeout: 1800s
storage_config:
hedging:
at: 250ms
max_per_second: 20
up_to: 3
# config for query frontend
frontend:
max_outstanding_per_tenant: 10240
log_queries_longer_than: 15s
compress_responses: true
downstream_url: querier.log-server-prod.svc.cluster.local:3100
frontend_worker:
frontend_address: querier.log-server-prod.svc.cluster.local:3100
grpc_client_config:
max_send_msg_size: 10485760
parallelism: 1
query_range:
max_retries: 5
Thanks!
