Facing issues when configuring Alloy for Windows on AWS EC2 instance
Hi there!
I have been trying to install and configure alloy in AWS EC2 Windows instance machine but got into few issues and have some questions.
Background: The alloy installed at below directory and has following files:
Directory: C:\Program Files\GrafanaLabs\Alloy
%PROGRAMDATA%
data-alloy
alloy-service-windows-amd64.exe
alloy-windows-amd64.exe
config.alloy
logo.ico
uninstall.exe
When I navigate to directory C:\Program Files\GrafanaLabs\Alloy and execute command ./alloy-windows-amd64.exe run C:\tmp\grafana-alloy.hcl the alloy runs fine and able to push the loki logs into grafana.
Note: grafana-alloy.hcl is my converted alloy file from Static agent.
However, I want to automate the process, and below commands does not write any logs.
Start-Process -FilePath “C:\Program Files\GrafanaLabs\Alloy\alloy-service-windows-amd64.exe”
sc.exe config ‘Alloy’ binPath= ‘"C:\Program Files\GrafanaLabs\Alloy\alloy-service-windows-amd64.exe" "-config.file=C:\tmp\grafana-alloy.hcl"’
Start-Service ‘Alloy’ - No errors but logged are not pushed.
Questions:
  1. What is alloy-service-windows-amd64.exe file used for? How it is different from alloy-windows-amd64.exe.
  2. What should be the binPath?
  3. ./alloy-service-windows-amd64.exe --help does not return anything. However, ./alloy-windows-amd64.exe --help does run alloy commands.
alloy-service-windows-amd64.exe is the windows service wrapper, you can find the details for it in the registry.
alloy-windows-amd64.exe is the actual alloy binary.
I install everything grafana in a folder called C:\LGTM
then for alloy I use nssm to install it with this parameter
