Facing EIO/Input-output errors when building Grafana on WSL2 (Windows 11)
Hi everyone,
I’m trying to set up and run Grafana from source on my Windows 11 laptop using WSL2 (Ubuntu 22.04), but I keep running into EIO/Input-output errors during yarn install and yarn start, especially when Nx/Webpack tries to write cache or build output files. I’ve tried cleaning all caches, reinstalling Node.js and Yarn multiple times, and ensuring my $TMPDIR and $GOCACHE are inside /home/samudrala, but the errors persist.
Errors I’m seeing include:
  • EIO: i/o error, open '/home/samudrala/grafana/.nx/cache/terminalOutputs/...’
  • EIO: i/o error, unlink '/home/samudrala/tmp/xfs-.../attw'
  • bash: /home/samudrala/.nvm/versions/node/v22.16.0/bin/yarn: Input/output error
My system specs:
  • Windows PC: DESKTOP-91QP86G
  • CPU: 12th Gen Intel Core i5-1235U @ 1.30 GHz
  • RAM: 16 GB
  • System type: 64-bit x64
What I’ve tried:
  • Removing and recreating all caches (.nx, tmp, node_modules, Yarn cache)
  • Using $TMPDIR and $GOCACHE inside WSL2 home folder
  • Reinstalling Node.js (v22.16.0) and Yarn multiple times
It seems like the issue is related to WSL2 filesystem I/O, but I’m not sure if this is a known limitation or if there are workarounds.
Questions:
  1. Do Grafana contributors generally use native Linux/macOS for building, or is WSL2 a supported workflow?
  2. Is there a recommended directory structure or setup under WSL2 to avoid these EIO errors?
  3. Are there any Node/Yarn/WSL2 configuration tweaks that help Grafana builds succeed?
Any guidance or tips would be greatly appreciated. Thanks contributors or maintainers…
