Hi, I have populated
prometheus.yml → scrape_configs → static_configs → targets
section using multiple IP addresses. There is no DNS functionality on prometheus server nor populating hostnames (instead of IPs) is possible.
- I want to create memory, cpu usage specific grafana panel using regexp based on nodename/hostname value. It should also have hostname in
legands. - Since
hostnameinfo is not available in default node_exporter metrics, I am exploring possibility of leveragingnode_uname_infometric which has hostname information. - I tried using
relabel_configsandmetric_relabel_configsbut it is not serving the purpose.
Can someone please help to understand possible solution ? Thanks in advance.
Possible metric to use:
node_uname_info{domainname="(none)",machine="x86_64",nodename="xy1dcxyz111",release="3.10.0-1160.81.1.el7.x86_64",sysname="Linux",version="#1 SMP Thu Nov 24 12:21:22 UTC 2022"} 1
