Extract a distinct value from a measurement based on day and time? (Utility tier pricing)
    Grafana v11.6.1 (ae23ead4d9) via docker container and influxdb v1
  • Extract a distinct value from a measurement based on day and time. Specifically, the value from pge_hourly_elec_rate_per_kwh from the day before yesterday at 10AM, 3PM, and 6PM. A bonus would be if I could identify weekend vs weekday easily as I see them implementing different rates based on day of week in the future.
  • I have a script that runs once per day to scrape my utility’s website for my rates. The rates are from two days ago as there is a slight lag in the data availability. So, a script that runs on 5/10 populates the utility rates for 24 individual values from 2025-05-08 00:00:00 to 2025-05-08 23:00:00.
  • Using the Day before yesterday timeinterval on the explore view I am able to view a day’s worth of rates.
What happened?
  • I can’t figure out the correct syntax to reference the specific three time slots of data.
  • Have 3 queries that result in the three distinct values for the three different times as relative time.
  • Bonus if there is a way to split this into six values for weekend vs weekday.
  • In Grafana: SELECT distinct("value") FROM "Utility Rate $/kWh" WHERE ("entity_id"::tag = 'pge_hourly_elec_rate_per_kwh') AND now-2d/d GROUP BY time($__interval) fill(null)
  • In Influx: SELECT distinct("value") FROM "Utility Rate $/kWh" WHERE ("entity_id"::tag = 'pge_hourly_elec_rate_per_kwh') AND time >= 1746687600000ms GROUP BY time(1h)
The “now-2d/d” syntax cant be used in an influx query. If you have a SQL datasource (e.g. postgres), you could make a variable that figures out the date you are interested in and get it in a unix timestamp format. Something like
SELECT extract(epoch from DATE_TRUNC($__timeFrom())
Then in the influx query, you could make 3 separate queries, each with WHERE time = ${mydate} + 10h
I haven’t tested this exact syntax, but it should work, perhaps with some minor modifications.
As you require rates from three distinct time you should simply modify you query to extract only those three specific times.
You can use three queries A, B and C The first for 10h00 the second for 15h00 and the third for 18h00.
Then you can use the Transformations to merge them into a single table.
Alternatively you could use your current query and the Computed columns, Filter, Group by Tab to do same
