Grafana Enterprise v11.0.0-68547 (15122bc71c) -
I have a time series data, trying to apply a threshold expression to it.
This is the data before applying threshold expression.
This should be the data after applying threshold ($A > 0)
I am able to do this on my local Docker Grafana (Grafana v10.4.1 (d3ce857c0e)) but not on the enterprise version. It just gives me no data when threshold expression is applied
By applying threshold expression to a timeseries data. Even by doing Math expression$A - 1doesn’t work -
What happened?
No data -
It should return a timeseries of booleans -
"datasource": {
"type": "prometheus",
"uid": "grafanacloud-prom"
"fieldConfig": {
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "red",
"value": null
"color": "orange",
"value": 70
"color": "yellow",
"value": 85
"color": "green",
"value": 95
"color": {
"mode": "thresholds"
"overrides": []
"gridPos": {
"h": 11,
"w": 12,
"x": 0,
"y": 3
"id": 82,
"options": {
"reduceOptions": {
"values": false,
"calcs": [
"lastNotNull"
"fields": ""
"orientation": "auto",
"showThresholdLabels": false,
"showThresholdMarkers": true,
"sizing": "auto",
"minVizWidth": 75,
"minVizHeight": 75
"pluginVersion": "11.0.0-68547",
"targets": [
"datasource": {
"editorMode": "code",
"expr": "delta(guardian_heartbeats[$__interval])",
"hide": true,
"instant": false,
"legendFormat": "__auto",
"range": true,
"refId": "A"
"conditions": [
"evaluator": {
"params": [
0,
0
"type": "gt"
"query": {
"params": []
"reducer": {
"params": [],
"type": "last"
"type": "query"
"datasource": {
"name": "Expression",
"type": "__expr__",
"uid": "__expr__"
"expression": "A",
"hide": true,
"refId": "B",
"type": "threshold"
"datasource": {
"type": "__expr__",
"uid": "__expr__"
"expression": "B",
"hide": true,
"reducer": "mean",
"refId": "C",
"type": "reduce"
"datasource": {
"type": "__expr__",
"uid": "__expr__"
"expression": "$C * 100",
"hide": false,
"refId": "D",
"type": "math"
"title": "Guardian Uptime",
"transformations": [
"id": "renameByRegex",
"options": {
"regex": ".*guardian=\"([^\"]+)\".*",
"renamePattern": "$1"
"type": "gauge"
* Did you receive any errors in the Grafana UI or in related logs? If so, please tell us **exactly** what they were.
No data error. That's it
* Did you follow any online instructions? If so, what is the URL?
Couldn't find any help online
