Can I add the expression for Grouping by matrix in the query section?
For reference this is where I want to add the expression:
And the transformation I am talking about is:
As much as I have understood your problem, I think this is what you’re trying to do. And I hope it will be helpful for you…
you cannot apply “Grouping to matrix” directly in the query.
It is a post-query transformation in Grafana, applied in the panel’s Transform section.
You can do it like this.
I have explained it with dummy data as an example.
Hello @koradeprajwal0212
Just checking in—did this solution resolve your issue, or are you still experiencing the same problem?
