Isaac
September 16, 2022, 10:25am
1
Hello, I am having some difficulties to export a HTML or TXT report with Github Actions.
I am executing this in my Github Actions.
When I execute this code, exports a JSON file in the Artifacts.
This is the JSON file
But I am trying to get a HTML or TXT file instead of a JSON file. If i do it with Visual Studio Code, it creates this reports.
This is the HTML file.
This is the TXT file.
I just need to create HTML report or txt report (see examples above) as an artifact in GitHub actions.
May you provide any support on this?
Hi @Isaac ,
If I understand correctly, you want to see the HTML/Text report after running the Github action. Since you’re generating HTML/Text outputs, you need to upload the generated files individually as you did with summary.json.
I hope this helps.
Isaac
September 16, 2022, 11:49am
3
Hi @inanc thanks for your reply, I’m afraid that I don’t quite get you, could you provide with a code example how to do what you indicate?
is it something like this?
Isaac
September 19, 2022, 7:39am
4
I got what you meant:
- name: Run k6 local test
uses: grafana/k6-action@v0.2.0
with:
filename: Report.js
flags: --out json=summary.json
- name: Upload performance test results
uses: actions/upload-artifact@v3
with:
path: summary.json
with:
path: summary.html
with:
path: stdout.txt
and results are uploaded:
Thanks a lot @inanc .
