I’m fresh of the boat when it comes to Grafana, so when I went through with the turorial I get an error on the prometheus when running this in Git BASH .
$ docker-compose up -d
tutorial-environment_grafana_1 is up-to-date
tutorial-environment_db_1 is up-to-date
Starting tutorial-environment_prometheus_1 ...
tutorial-environment_loki_1 is up-to-date
tutorial-environment_promtail_1 is up-to-date
Starting tutorial-environment_prometheus_1 ... error
ERROR: for tutorial-environment_prometheus_1 Cannot start service prometheus: error while creating mount source path '/run/desktop/mnt/host/c/Users/H▒kon/tutorial-environment/prometheus': mkdir /run/desktop/mnt/host/c: file exists
ERROR: for prometheus Cannot start service prometheus: error while creating mount source path '/run/desktop/mnt/host/c/Users/H▒kon/tutorial-environment/prometheus': mkdir /run/desktop/mnt/host/c: file exists
Encountered errors while bringing up the project.
When checking how everything went, which is the next step in the tutorial, I get this:
$ docker-compose ps
Name Command State Ports
tutorial-environment_app_1 /bin/sh -c /app http://db ... Up 0.0.0.0:8081->80/tcp
tutorial-environment_db_1 /db Up 0.0.0.0:8082->80/tcp
tutorial-environment_grafana_1 /run.sh Up 0.0.0.0:3000->3000/tcp
tutorial-environment_loki_1 /usr/bin/loki -config.file ... Up 0.0.0.0:3100->3100/tcp
tutorial-environment_prometheus_1 /bin/prometheus --config.f ... Exit 128
tutorial-environment_promtail_1 /usr/bin/promtail -config. ... Up
And this was after the first time running. I tried running the codes again, tried stopping the services (as the tutorial recommend trying), as well as deleting the files downloaded in docker and running all the code again (same thing happens). This causes an error HTTP Error Bad Gateway in step 4 of the Grafana fundamentals.
Does anyone have any ideas on how to fix this. As stated, I’m completely unexperienced here, so it’s probably something obvious. Thanks for your help in advance.
