I was following this guide http://docs.grafana.org/project/building_from_source/ to install grafana on my local.
I face the below error when i run the command “grunt”,
/srv/data/sources/src/github.com/grafana/grafana/node_modules/grunt/node_modules/findup-sync/node_modules/lodash/dist/lodash.js:46
reEmptyStringTrailing = /(__e(.*?)
SyntaxError: Invalid regular expression: missing /
at exports.runInThisContext (vm.js:73:16)
at Module._compile (module.js:443:25)
at Object.Module._extensions…js (module.js:478:10)
at Module.load (module.js:355:32)
at Function.Module._load (module.js:310:12)
at Module.require (module.js:365:17)
at require (module.js:384:17)
at Object. (/srv/data/sources/src/github.com/grafana/grafana/node_modules/grunt/node_modules/findup-sync/lib/findup-sync.js:16:9)
at Module._compile (module.js:460:26)
Any idea?
FYI:
node version: v0.12.0
nodejs version: v0.10.25
npm version: 2.5.1
go version go1.5 linux/amd64
machine: Linux
Thanks in advance for your help
