Error reading Prometheus: Post "/api/v1/query": unsupported protocol scheme ""
I got following message when I tried to save the Prometheus data source
Error reading Prometheus: Post “/api/v1/query”: unsupported protocol scheme “”
grafana-enterprise-8.3.3.linux
prometheus-2.32.1.linux
same exact error… both grafana and prometheus installed on a lxc, using ubuntu 21 container. I am able to save the default data source, but the error “Error reading Prometheus: Post “/api/v1/query”: unsupported protocol scheme “”” is always there at the bottom of the screen - either during data source save or when trying to run any query in explorer…
prometheus, version 2.32.1, grafana * v8.3.3 (30bb7a93ca)
Ubuntu 21.04, proxmox container.
EDIT: I can repro the same scenario when running from a ubuntu20 VM, so does not seem to be container-related…
I just encountered this… I saw that the Prometheus URL was pre-filled with the correct value. HOWEVER, I had to actually type in the same URL as the default (http://localhost:9090) for it to work.
Hope that helps.
confirmed on my end - typing the default value http://localhost:9090 instead of keeping it default - works! Thanks!
It’s because of missing the protocol. Adding “http://” protocol in front of the .… in the URL field solved the problem.
