Hi All,
Getting the error “database is locked”, i tried to change DB as well but no luck,
I am waiting the your valuable the input.
Thanks
Gulab
Hi @gulabnandanvar,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community
This seems to be a known issue as previously reported here:
Please check it and let us know if that helps you to find the answers to you need.
Update Status
This issue has been fixed with major significant improvements on the Backend Database.
Therefore marking it as a solution
bgates
3
Wanted to tag onto this.
I was receiving this error randomly in our alerts and when we would run some queries.
The issue was around the default grafana.db sqlite3 file.
Transitioned to MYSQL and have had 0 issues.
you were running queries again the grafana sqlite?
I’m getting a lot of these as well as high CPU/memory usage
@jasonmallory
Does it prevent you from using grafana? Also are you querying the sqlite db itself?
Maybe it’s time to migrate to mysql or postgres
I think I’m going to move that direction this week
And yeah Grafana will lock up the server
bgates
9
No was just doing alot with grafana and sqlite could not keep up
