I have enabled tls for grpc server which works perfectly fine. However, when I set “tls_insecure_skip_verify: false” in all grpc clients, I am getting below error
level=error ts=2024-12-21T19:33:54.344126319Z caller=ratestore.go:303 msg=“unable to get stream rates from ingester” ingester=x.x.x.x:9095 err=“rpc error: code = Unavailable desc = connection error: desc = "transport: authentication handshake failed: tls: failed to verify certificate: x509: cannot validate certificate for x.x.x.x because it doesn’t contain any IP SANs"”
level=error ts=2024-12-21T19:33:55.457565818Z caller=ratestore.go:303 msg=“unable to get stream rates from ingester” ingester=x.x.x.x:9095 err=“rpc error: code = Unavailable desc = connection error: desc = "transport: authentication handshake failed: tls: failed to verify certificate: x509: cannot validate certificate for x.x.x.x because it doesn’t contain any IP SANs"”
All certificates have correct domain names.
The common config is as below.
auth_enabled: true
common:
compactor_address: 'https://loki-backend:3100'
path_prefix: /var/loki
replication_factor: 1
storage:
s3:
bucketnames: chunks
insecure: false
region: us-east-1
s3forcepathstyle: false
compactor:
compaction_interval: 10m
delete_request_store: s3
retention_delete_delay: 2h
retention_delete_worker_count: 150
retention_enabled: true
working_directory: /var/loki/data/retention
compactor_grpc_client:
tls_ca_path: /etc/rmagdum/pki/client-certs/ca.crt
tls_cert_path: /etc/rmagdum/pki/client-certs/tls.crt
tls_enabled: true
tls_key_path: /etc/rmagdum/pki/client-certs/tls.key
frontend:
grpc_client_config:
tls_enabled: true
max_outstanding_per_tenant: 1024
scheduler_address: ""
tail_proxy_url: http://loki-querier.rmagdum.svc.cluster.local:3100
frontend_worker:
grpc_client_config:
tls_enabled: true
index_gateway:
mode: simple
ingester:
max_chunk_age: 2h
ingester_client:
grpc_client_config:
tls_enabled: true
limits_config:
discover_log_levels: false
discover_service_name: []
ingestion_burst_size_mb: 128
ingestion_rate_mb: 64
max_cache_freshness_per_query: 10m
per_stream_rate_limit: 128M
per_stream_rate_limit_burst: 256M
query_timeout: 300s
reject_old_samples: true
retention_period: 24h
split_queries_by_interval: 15m
volume_enabled: true
memberlist:
join_members:
- loki-backend.rmagdum.svc.cluster.local
- loki-read.rmagdum.svc.cluster.local
- loki-write.rmagdum.svc.cluster.local
pattern_ingester:
enabled: false
querier:
max_concurrent: 1024
query_range:
align_queries_with_step: true
query_scheduler:
grpc_client_config:
tls_enabled: true
max_outstanding_requests_per_tenant: 1024
ruler:
storage:
s3:
bucketnames: ruler
insecure: false
region: us-east-1
type: s3
runtime_config:
file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
configs:
index:
period: 24h
prefix: index_rmagdum
object_store: s3
schema: v13
store: tsdb
server:
grpc_listen_port: 9095
grpc_tls_config:
cert_file: /etc/rmagdum/pki/server-certs/tls.crt
client_auth_type: RequireAndVerifyClientCert
client_ca_file: /etc/rmagdum/pki/server-certs/ca.crt
key_file: /etc/rmagdum/pki/server-certs/tls.key
http_listen_port: 3100
http_server_read_timeout: 600s
http_server_write_timeout: 600s
http_tls_config:
storage_config:
aws:
bucketnames: ${BUCKET_NAME}
s3: s3://${AWS_ACCESS_KEY_ID}:${AWS_SECRET_ACCESS_KEY}@${BUCKET_REGION}
boltdb_shipper:
index_gateway_client:
server_address: dns+loki-backend-headless.rmagdum.svc.cluster.local:9095
hedging:
at: 250ms
max_per_second: 20
up_to: 3
object_prefix: rmagdum/loki-s3
tsdb_shipper:
active_index_directory: /var/loki/data/tsdb-index
cache_location: /var/loki/data/tsdb-cache
grpc_client_config:
tls_enabled: true
tracing:
enabled: false
