I want to setup an Loki system (single Loki and single promtail run on the same machine) with enabling client certificate authentication, here is my steps:
Step 1: follow this Securing Grafana Mimir communications with TLS | Grafana Mimir documentation to generate server certificate and client certificate , the server certificate is for loki, and the client certificate is for promtail
Step 2: config loki as below
auth_enabled: false
server:
##http_listen_address: 127.0.0.1
http_listen_port: 3100
grpc_listen_port: 9096
http_tls_config:
cert_file: /usr/allen/loki/cert/server.crt
key_file: /usr/allen/loki/cert/server.key
client_auth_type: RequireAndVerifyClientCert
client_ca_file: /usr/allen/loki/cert/root.crt
Step 3 start loki
Step 4: config promtail as below:
positions:
filename: /tmp/positions.yaml
clients:
- url: https ://localhost:3100/loki/api/v1/push
tls_config:
cert_file: /usr/allen/loki/cert/client.crt
key_file: /usr/allen/loki/cert/client.key
server_name: localhost
Step 5: after I start promtail, I got below error
level=warn ts=2022-12-21T12:47:42.902570068Z caller=client.go:379 component=client host=localhost:3100 msg=“error sending batch, will retry” status=-1 error=“Post "https ://localhost:3100/loki/api/v1/push": x509: certificate relies on legacy Common Name field, use SANs instead”
Step 6: then I set the insecure_skip_verify to be true in promtail config file:
positions:
clients:
tls_config:
insecure_skip_verify: true
Step 7: After restart promtail, I got below error
level=warn ts=2022-12-21T12:50:34.649898921Z caller=client.go:379 component=client host=localhost:3100 msg=“error sending batch, will retry” status=-1 error=“Post "https ://localhost:3100/loki/api/v1/push": remote error: tls: bad certificate”
Can someone tell me is there anything wrong with my configuration? How can I make it work? Thanks a lot.
